I’ve got a a bro gram 5005 turntable that plays too fast. The speed could do with slowing a touch to play correctly. Is there a straightforward was to adjust the paying speed?
The speed adjustments mentioned in the user manual?
hello
Below the turntable, on the left side, there are two openings underneath which are potentiometers for setting the speeds 33.333 UPM and 45 UPM
look at this thread toohttps://archivedforum2.beoworld.org/forums/t/30272.aspx
wilfried
