NL/ML Converter with Beosound 9000 and Besound/Beomaster5
This post has 1 Reply | 3 Followers
Joe
Dallas, TX
Posts 38
Joe Posted: Thu, Mar 21 2019 5:29 PM
Hoping somebody can help me? I powered down the above devices for sometime. Recently I powered everything up again, the NL/ML converter doesn't recognize  the the BS/BM5 nor the 9000 player as it did before.
Should I power down the converter, then plug each source in one at a time so the converter will recognize these sources? Should each source be on and playing before try to add each one?
Note all of the above worked perfectly before I powered everything down, with the converter connected to the Beovision Avant and attached speakers.
Anyone else had this issue?
Thanks..Joe
f5434964
Austria
Posts 206
f5434964 replied on Fri, Oct 18 2019 8:26 AM
Hello!
I do not have an answer but I would just try to power up the product again one after the other starting with the converter
had the issue that converter did not provide TV-sound to ML network; a hard reset (unplugg) helped me out...
otherwise you would have to setuo the converter menu...
best regard Elmar
Page 1 of 1 (2 items) | RSS
