New B&O TV BeoVison Harmony
This post has 369 Replies | 3 Followers
Roger
Norway
Posts 417
Roger replied on Fri, Apr 12 2019 2:03 PM
Agree, Emil - but the Harmony is a stand and sound solution only compatible with the C9 panel from LG. Same goes for the new sound bar.
Roger
Millemissen
Flensborg, Denmark
Posts 14,680
Roger:
Roger
Oh, well - and when will we be introduced to that 😉
Millemissen
Flensborg, Denmark
Posts 14,680
BEOVOX141:
Millemissen:
B&O would have had to engage in the whole tuner business again - unless the have been able to integrate ‘the C9-tuner option’ into the sound/stand-center.
No, today the tuner is pretty much a SOC, making it entirely a software exercise, Or you simply buy an OEM module at around 15 us$ in quantities.
Nor talking about the hardware, but the sw - this would have to be similar to the ui of the tv....I’d suppose.
In the video we did not see any antenna connection/s in the V300 part.
Roger
Norway
Posts 417
Roger replied on Fri, Apr 12 2019 2:15 PM
Millemissen:
Roger:
Roger
Your dealer will be invited to København juster after Easter for a hands-on session with itCool
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks - I’ll speak to him right away....and after.
(And the new remote?)
Roger
Norway
Posts 417
Roger replied on Fri, Apr 12 2019 2:24 PM
Perhaps get a one-night-only part-time job at the dealership, and join him - you may get to see the new sound product sitting between the BS2 and the A9 as well as the new remote. This meeting will be important as the info surrounding the integration with LG is confusing at best (for the dealers).
Roger
Sandyb
Posts 2,186
Sandyb replied on Fri, Apr 12 2019 2:25 PM
The connection panel on the back of the LG C( unboxing looks slightly different to the one in the B&O setup video.
In the latter, there are terminals for connection of a sub etc, and a couple of other small differences.
Not sure if that matters or means anything, or is just a region thing, just saying...
And yes, there is no reason why the tuner would be disabled in the Harmony LG panel
Also if you look closely at the speaker part of the Harmony, it does look like there are PUC connections...i.e. much the same as the Eclipse etc (and previous)......
AnalogPlanet
Vienna, Austria
Posts 678
Millemissen:
I wonder what happens, if you install the app on a C9 without the Harmony stand/system.....will it then be controlable with the BeoRemote One?
That was exactly my first question too. Big Smile
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Fri, Apr 12 2019 2:58 PM
Millemissen:
You are right,- No CA slots either come to think of it, and the whole RF part was basically left unconnected.Confused
Millemissen
Flensborg, Denmark
Posts 14,680
Sandyb:
Isn’t that what we could call a BeoSystem 4/Audio (or BeoSystem 5, if you please).
Internal name V3000.
Millemissen
Flensborg, Denmark
Posts 14,680
Millemissen:
Sorry - V300
Sandyb
Posts 2,186
Sandyb replied on Fri, Apr 12 2019 3:13 PM
Absolutely yes.
No controversy there.
Millemissen
Flensborg, Denmark
Posts 14,680
Sandyb:
Absolutely yes.
Only ‘drawback’ - will that be available as a standalone solution?
If yes, then only for a combination with the new LG-tv’s.
Sandyb
Posts 2,186
Sandyb replied on Fri, Apr 12 2019 3:54 PM
believe so, as part of a centre speaker / sound product.
I suspect it will be usable with non LG screens as well, but perhaps in not the same, lets call it, semi-integrated, way as seems to be the direction for newer LG TV's. New Panasonic or Sony tv's will not have this B&O specific chip / firmware in that the newer LG models do.
But that product seems to be late this year, early next, so we might need to take a breath on that one.
One difference I guess with this and the older BS4 platform was the lack of ARC / CEC - that will clearly be different now, so that constraint will disappear.
Whether the PUC that seems present in the Harmony survives into this new product, who knows, but the signs are looking good i guess (truly a guess).
Anyway, not sure how may forum members are that fussed about chosing a different OLED than LG - they are good all rounders, so for many LG will be more than enough (especially our friend on his thread, who is back to talking to himself again I see).
Michael
Sweden
Posts 2,578
Michael replied on Fri, Apr 12 2019 4:22 PM
Sandyb:
What is this chip and where is the source? I find it hard to believe that they would put a special chip inside the tv. Makes no sense, why? The app probably does everything necessary to give a visual interface for configurations of the “Beo” part of the assembly, like setting up speaker configurations and hdmi port with their pucs.
I gather that those things are managed by the beo-part on it’s own and that the tv is simply a screen. It has its own configuration for picture and the beo part only turns the tv on and off, including some simple things like maybe change sources (although most of them are on the harmony itself).
The Ethernet cable seems only to be pass through to make cabling nicer. I believe the data is over hdmi since it transports Ethernet, usb and sound as well as video two way.
Sandyb
Posts 2,186
Sandyb replied on Fri, Apr 12 2019 4:31 PM
Be it a chip or firmware, there seems to be something in the newer LGs (all new LG’s I’ve been told), that will make the TV appear to other B&O products, and vice Verda I guess.
How it all works I have no idea, but it sounds like more than a simple setup assistant, and something a bit broader I suppose.
Michael
Sweden
Posts 2,578
Michael replied on Fri, Apr 12 2019 4:43 PM
Sandyb:
I think the thing you are referring to is the app itself. Can’t imagine what else it would be. The device is also supposed to work with third party devices so.
The setup video shows nothing special either so I don’t think there is anything special at all about the TVs. They are new and have more updated specs (hdmi 2.1 for example) and those things might be requirements that the harmony has. But a special chip, seems unrealistic.
Sandyb
Posts 2,186
Sandyb replied on Fri, Apr 12 2019 5:01 PM
Guess we will find out over the next few months, so we will see.
In the end, if we end up in a place where 3rd party screens can be easily integrated with B&O audio, isn't that what many have wanted? (however it is done, within reason).
Millemissen
Flensborg, Denmark
Posts 14,680
Sandyb:
Has it ever occured to you, that the coopreation with LG might include, that only LG-tv’s can be used.
Or rather only tv’s with WebOS (4.5).....which again only can be from LG.
I see no signs of a hardware solution/chip built in to the tv.
And it was a stock LG/C9, that was unpacked in the video - there has only been talk about the app.
But, yes - you may be right, that is what most people want anyway.
Sandyb
Posts 2,186
Sandyb replied on Fri, Apr 12 2019 5:25 PM
Millemissen:
Sandyb:
Sure, it sounded surprising to me when I heard it.
And if its firmware that is specific to LG tvs or some LG tvs, then that would seem less surprising.
But in the end what does it matter really - what is being suggested is that somehow LG's will be a bit more able to be integrated with other B&O equipment.
I doubt that would extend to excluding other brand TV's, but I suspect they would be usable in a more rudimentary way with other B&O speakers.
Let's see what this Lg integration actually means or extends to first, and then we will be in a better position to see what that means for, say, a Panasonic OLED.
AnalogPlanet
Vienna, Austria
Posts 678
While not perfect with mentioned limitations, I think that concept is buyer-friendly. Helps me to justify high cost of B&O sound center. And actually stimulates me to actively consider investing into a new B&O purchase - something I couldn‘t justify with previous TV sets.
Epsilon20
Posts 58
Epsilon20 replied on Sat, Apr 13 2019 10:54 AM
Not sure if you guys saw this video of the Milan show
https://youtu.be/Y0CkQzXyPsY
Beovision Eclipse 55 Brass Edition with Oak covers and Brass Orbital stand
Beolab 50s silver & Oak, Beolab 18 Brass with Smoked Oak, Beolab 18 Rose Gold with Maple Covers, Beolab 19 Black.
benoit
France
Posts 646
benoit replied on Sat, Apr 13 2019 11:33 AM
Epsilon20:
And already not well aligned Crying ... I'm not very optimistic on how well it will resist to the time.
And for this price I would for sure go for the LG rollable model and not for the LG B&O one.
Epsilon20
Posts 58
Epsilon20 replied on Sat, Apr 13 2019 12:16 PM
I think having seen everything I'd rather get the rollable TV too. Has LG announced pricing yet? assuming all LGs have built in B&O support I'm in.
Michael
Sweden
Posts 2,578
Michael replied on Sat, Apr 13 2019 12:24 PM
Epsilon20:
I don’t think the first rollable TVs or maybe any would be a great or even good investment. The material is prone to damage and won’t stay flat. The first bendable phones are showing bulges and blobs even after one use. A tv that bends into a roll every day? Not optimal... cool though. And in the future probably not impossible but for now it’s quite a sophisticated surface with many different layers that has to withstand force and be able to be completely flush every time.
Millemissen
Flensborg, Denmark
Posts 14,680
Epsilon20:
The pricing is known - you can easily google that.
Feel free to be a firstmover and please report back here.
How come you would assume that there should be any ‘built B&O support’ with that tv?
benoit
France
Posts 646
benoit replied on Sat, Apr 13 2019 12:43 PM
Epsilon20:
I remember having read that LG told 15000-20000€. But I found a recent article telling that according to rumors it could be 7000 only (https://actualites.rue-montgallet.com/lg-annonce-la-sortie-du-premier-televiseur-enroulable-lg-signature-oled-tv-r/) but I don't believe it as it's the price of the 2019 wallpaper OLED in 65 inches....
poodleboy
Posts 303
poodleboy replied on Sat, Apr 13 2019 3:41 PM
It will require a special large room and a customer with special taste and means, but it is the first that has been a positive awakening in a VERY long time.
I think it is a grand concept and can spin off a wide range of sizes and finishes to meet a wider audience. Sure don't see why the sound system could not be independent of the LG screen unless part of the agreement or lack of interest.
The luxury experience is far more than product and style, so I hope B&O will ensure that the quality, tech, and support will be up to the task.
And I haven't seen it, heard it, or expect to for a very long time.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Apr 13 2019 9:02 PM
One could say it Sparkles!
Jeff
KMA
Posts 621
KMA replied on Sat, Apr 13 2019 9:22 PM
Michael:
Indeed, there is no special "B&O chip" in the LG OLEDs used with Harmony.
Three requirements:
1) WebOS 4.5
2) LG firmware for C9 and later
3) The B&O App for WebOS 4.5, available from the LG content store.
The App handles the integration between the LG TV & Harmony stand / sound center.
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
Mikipidia
Posts 2,169
Mikipidia replied on Mon, Apr 15 2019 1:50 AM
some quick more info,
soundcenter is as wide as a 65'' screen, for all the sizes above they use wider panels, so same soundcenter for 65'', 77'', 88''. The only thing that's different between then is the width of the panels.
Also the soundcenter weighs about 80 kg
more info in this YouTube video(notice the panels not lining up flush...)
https://www.youtube.com/watch?v=Y0CkQzXyPsY
Michael
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Manbearpig
Posts 908
Manbearpig replied on Mon, Apr 15 2019 12:19 PM
Thanks for the video, Michael. Good one. I very much like the design of the TV and what they did with that set. Really appreciate the effort of thinking out of the box. I also find the movement to be quite beautiful. However, price tag is a minus. Prizes for televisions have went up way too high recently for my liking. I mean, who can still afford almost 20000 for a TV? I still hope for B&O that the television sells. Good job on the design (and probably also performance).
Cheers,
Kai
Mikipidia
Posts 2,169
Mikipidia replied on Mon, Apr 15 2019 1:34 PM
Don’t forget though that for the current 18.5k euro price you get the whole hog including floorstand and oak/wood panels. The cloth one is a good 1.5k less. And above all they said that they would follow lg’s prices and they usually drop the tv panel by a grond or so in september. Here in NL the c8 77” is now nearly 4K euro less than when they started selling them.
andybandy
Posts 164
andybandy replied on Mon, Apr 15 2019 3:05 PM
This is a early sample, and I trust B&O that will fix this in the launch version.
This is an normal standard, when they need to be hurry to show this to the milano show.
The products is not finish, and smal change will fix this, so I whold not be worry about this :)
I think about this alignment. I could not answear the early post. I never find out how to do, I press quick replay under the post, but it start a new. :( so sorry for its not correct answear:)
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Apr 15 2019 3:38 PM
andybandy:
Someone already mentioned it on the previous page.
Not only I did I think this looked poor, but a guy from B&O is sitting in front of it whilst it's happening and acts as nothing irregular has happened.
andybandy
Posts 164
andybandy replied on Wed, Apr 17 2019 10:17 AM
Off course, the B&O guy is acting Professional:) Why should he reacting on that in the big stage.
They take it back to the production area, and work on it:) its not autumn yet. Spring just start in Scandinavia :)
I belive this is working great out back in struer, before launch.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Apr 17 2019 4:09 PM
andybandy:
I agree, when you're on stage in front of everyone doing a demo, if the hardware or software dumps on you, you just have to tap dance and go on. Sometimes you get lucky and it's something harder to notice but in my career ir usually always decided to do it in a very obvious way.
Jeff
Michael
Sweden
Posts 2,578
Michael replied on Wed, Apr 17 2019 4:52 PM
I wish they made a sound center with magic movement of speakers only. That way easier to integrate a wall mount tv and or projector. Also easier to update later on. A Tv or projector is really only necessary for showing an image.
The sound system could turn it on and off and probably also adjust a VESA mount (that B&O either could design too or open up for integration with for example vogels electrical stands. Most TVs can be turned on and off through other systems and projectors usually have support for this as well.
Having a sound system making its own welcome dance would be cool and less weird when it doesn’t have to rely on the screen design. I know it wouldn’t be optimal for everyone but it would be a great way for B&O to widen their customer base as well as making a system that would work for a longer time and enable upgrades more fluidly.
mikewalsh
Posts 13
mikewalsh replied on Mon, Jun 3 2019 11:04 PM
So does that mean that if you buy the 77-inch Harmony, and later you want to upgrade to the 88 inch panel - the soundcenter/lift mechanism is exactly the same - and you can just swap to the bigger size?
Mikipidia
Posts 2,169
Mikipidia replied on Mon, Jun 3 2019 11:17 PM
mikewalsh:
yes and if you want to the accompanying covers so it all lines up again, same if you wanted to ''downgrade'' to the 65''
Page 7 of 10 (370 items) « First ... < Previous 5 6 7 8 9 Next > ... Last » | RSS
