HI All.
I have a set of Beovox 3705, 3 way speaker I inherited a while back. I can find virtually no information on these speakers. Can anyone help? I have a lot and serial number of the speaker set (Lot G, Serial 001132). On the sticker on one of the speakers I have found 4 Ohm 40 (75) W.
Thanks & Regards
Jan
There is no Beovox 3705 model. Probably 3700 or 3702?
Maybe with right model number you can find information you are looking for...
Theomaster
Vintage Bang & Olufsen
I'm 100% sure I have the right model number. Hence I'm battling to find info.
There was a discussion long time ago:
https://archivedarchivedforum2.beoworld.org/forums/t/22249.aspx
sadly without pictures.
But even our guru was clueless
Maybe he has more info meanwhile...
hx
hemenex: There was a discussion long time ago: https://archivedarchivedforum2.beoworld.org/forums/t/22249.aspx sadly without pictures. But even our guru was clueless Maybe he has more info meanwhile... hx
Interesting. Maybe I am wrong than.
Pictures would help us
How do I add a picture?
When you click reply you will see the OPTIONS tab at the top click it and you will see you can add a file or picture to your post.
Regards Keith....
Hi All..
This is my first post to the forum. As i'm also looking at more info on the exact same speakers. Not an active member just registered to post some pictures. Can only add one picture on a post
Stay save
+1
+2
+3
Technically these are Beovox 3702 in a 1960s cabinet design (like Beovox 1200/3000).
An export model for South Africa.
Thanks. So its an south african only model. I see some pops up for sale in South africa every once in awhile.
