Hi everyone,
I have recently refurbished BeoMaster 6000 type 2253 and upon testing it it appears that built in clock is running with 10 minute delay every hour. For example I am setting it up for 12:00 and in one hour it will show 12:50.
Any advice?
Vitaly
A 60Hz Beomaster running on 50Hz?
There is indeed a 50/60hz pin on the 8032 :)
Hi Martin, Indeed. Is there a fix for that?
Kindest regards,
Hello Flerbizky, would you please point out where is that pin?
Kind regards,
The mains frequency signal goes from 16TR4 to pin 16 on the CPU.
