Hello!
I want to play a bit with the combination of beomaster 7000 with playmaker 2930
Searched on google and can't find pinout to solder a cable.
I found this, but it´s not rj45
Powerlink:Pin 1 = Power link on; on > 2.5V, off =<0.5VPin 2 = Signal gndPin 3 = LeftPin 4 = Speaker on/mute; on > 2.5V, off =<0.5VPin 5 = RightPin 6 = Data; High > 3.5V, low < 0.8VPin 7 = gndPin 8 = Not used anymore, used to be speaker/amp overloadAudio Aux link:Pin 1 = Left inPin 2 = Signal gndPin 3 = Left outPin 4 = Right inPin 5 = Right outPin 6 = Data; High > 3.5V, low < 0.8VPin 7 = Not used
Thx
Hi aiscom,
Welcome to Beoworld! I have the cables ready made with the special wiring for PlayMaker to Beomaster 7000 (ie. if your speakers are connected to the 7000), if you decide not to solder your own cable:-
https://soundsheavenly.com/playmaker-and-essence-wireless-streaming/84-378-rj45-to-aux-input-cable-airplay-on-your-bo-system.html#/9-length-18m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Hello Steve!Thanks for your answer.I already found your link in an other threat.I need to solder it, because in the apartment I moved, I'm not allowed to make a hole from one room to an other. There is on old network cable going the way I need, so I could youse it.Would be nice, you could tell me the right wiring.thxGuido
Were you able to find the solution? I'm looking too but can't see any.
Teyelvis: Were you able to find the solution? I'm looking too but can't see any.
Scroll down this thread to the 31 Dec 05 post: http://www.hifi4all.dk/forum/forum_posts.asp?TID=32157&P%20N=1
Appreciate the pointer. Working now
Cheers
