Got a beogram 5500 that i bought off caigslist and it had a broken tab on the drive string i fixed the tab with a bolt and rerouted the drive string the turntable spins but stops almost imediatly when i try to cue it it blo0ws the fuse it tried to manualy turn the cueing wheel but it will not move the tonearm its alomost as if its stuck the string moves freely if i move it by hand so i am not sure what is causing the bing on the cueing wheel unless the grearing is out of synch thanks
