I have a beomaster 2400. What speakers that you currently available from B & O would be the best match for her?
Hi, and welcome!
Simple answer: none.
You'll have to choose from the vintage passive speakers. I’d advise S45.
Jacques
What Jacques just said - or the larger S60 or S75.Despite what the FS says, speakers can only be too small.
Totally agree with Dillen,- Why not Passive Pentas?
The FS..... ?
FS = The Fabric Selector. - An old story - do a search here in the forum.
lol,- I was close guessing at something like "the Feminine side"...
I ran a BM2400 with S75s for many years and was very happy with the sound - lots of bass - a bit blowsy but good with rock. If you are more into classical, get S45.2s and make sure you get the stands.P45s are an interesting and cheaper alternative and are wall mounted.
You can use active speakers if you really want but you will need attenuating cable (high resistance to bring level down to line level ) Steve at Sounds Heavenly can help. If you went that way, I would get second hand Beolab 4000 Mk 1s - but passive would be more sensible.
Peter
