Beoplay A9 Mk.4 - experience?
BlindZenDriver
Posts 8
BlindZenDriver Posted: Sat, Jun 1 2019 10:39 PM
So I see there is a new A9 and as I am looking to maybe acquire an A9 it has me wondering which version to go for (I was about to pull the trigger on the Mk.3, but now...).
As I understand the Mk.3 and Mk.4 share a lot only there are some change to the electronics, where especially the 4 supposedly using a microphone to adapt to the room it is installed in has my interest. I imagine it comes with a microphone in the box, so that one can easily redo the calibration when needed (My car stereo has that and there it takes a few minutes, as it runs through every speaker in the car - easily done).
Please if anyone can describe how the room adaptation worked out?
And a comparison with the previous generations of A9 would also be very welcome.
Also and this isn't really an audio quality thing. If possible please confirm that the Google listening thing can be disabled.
Jaffrey2230
Washington DC
Posts 520
I have an A9 MKII with AirPlay 2. The audio quality is excellent - better than my BL8000 + BL 2 combo.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
peterafox
Posts 34
Hey... there’s a review here on YouTube from the Manchester store... explains the differences and Google Assistant options well.
https://youtu.be/VQVzFqwRokI
Aussie Michael
Melbourne, AU
Posts 3,730
I have a Mk2 and it's excellent, so i can only imagine the power bump and extra rear speaker in the Mk3 and 4 is only going to make a good thing even greater.
BlindZenDriver
Posts 8
peterafox:
Nice.Thank you.
That review pretty much brought the answers, not sure how I missed finding that video.
Just to also have the answers here in this thread:
  • The room calibration is done by the A9 playing a test sound and measuring the result, no sight of an external microphone so it must be using a microphone on the A9 unit itself. Having the room calibration feature does away with the room placement selector found the previous versions of the A9 and going by the review there is an improvement in audio quality.
  • The google assistant can be turned off. When done so it is indicated by four red LED's that can be seen through the fabric that covers the front of the A9, if not disabled those four LED are instead white - not sure if the white ones are on all the time or not but apparently they are when red.
The Manchester review video suggests one can block off the LED using a piece of tape, good thing this will then be hidden behind the front cover except with the fabric cover being cumbersome to place it will be annoying if they are needed for anything else than the Google thing.
Also, thanks to Jaffrey2230 and Aussie Michael
Millemissen
Flensborg, Denmark
Posts 14,680
https://youtu.be/Xo4ne9ED30A
Page 1 of 1 (6 items) | RSS
