Does anyone know if it's possible to create a Link Audio V.AUX command in the config tool for the beo5? I can see the option to add Link in the IR command, but not Audio.
The goal is to have my beocenter 6 play the audio only (in stereo) with screen off from V.AUX on my avant 32 over masterlink. The beocenter 6 already has a v.aux input in use which is why it needs the Link command added.
Many thanks for the help.
Rob.
You can select TV, RADIO, VTR mode.
Just select RADIO - it`s the same as AV with a video source.
Stefan
