Beosystem 4 - change display
This post has 11 Replies | 3 Followers
frog
Camberley UK
Posts 624
frog Posted: Sun, Jun 9 2019 6:09 PM
hi,
on moving from a Beosystem 3 to a 4, what I’m missing is the service option to remove screen auto detect and select which Beovision I am connecting to manually. Does anyone know if there is a service option apart from the Red-Go on setup? Maybe another hidden menu somewhere
Tassos
Athens
Posts 323
Tassos replied on Fri, Jan 8 2021 6:42 AM
Hello frog,
I am on the same page with you on this one and I was curious if you have solved it. I have a beosystem 4 connected to an atlona switcher (5 inputs, 2 mirrored outputs but I am currently using only one input and all stb are connected on beosystem), on which an epson projector and a beoplay v1 are connected. The manual says that if a beovision is connected to it it is automatically detected by beosystem 4. Unfortunately this is not the case for my setup. Any ideas?
Thank you
beojeff
USA
Posts 2,012
beojeff replied on Sat, Jan 9 2021 12:36 PM
A part of the autodetect is for the BS4 to know if the Atlona swtich with the special B&O firmware is connected for the Cinema function of having both a tv and a projector. When this is detected, new options are available in the menu to setup both a tv screen and a projector.
This isn't really an answer to the OP. Just some interesting info.
Tassos
Athens
Posts 323
Tassos replied on Sat, Jan 9 2021 12:49 PM
Thanks for the answer I have read about the atlona switch with the special firmware but I cannot recall the exact model. Do you remember it?
Thank you
kimchr
Posts 170
kimchr replied on Sat, Jan 9 2021 3:48 PM
AT-HD4-V42-B&O it is a standard Atlona flashed with B&O firmware.
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Sat, Jan 9 2021 6:03 PM
hi,
you can use any Atlona AT-HD4-V42. there is no specific firmware or version. (info from b&o and atlona support) I use the Atlona AT-HD4-V42 with the beosystem 4 with projector and a upgraded beovision 9 (with deactivated beosystem 3). When the beosystem 4 detects the AT-HD4-V42 on the hdmi output, an additional menu appears for the two hdmi outputs . do you know the service manual for the cinema (2nd screen) installation of the beosystem 4?
beoandy
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
beojeff
USA
Posts 2,012
beojeff replied on Sun, Jan 10 2021 12:38 AM
beoandy:
hi,
beoandy
This is not true. You must have the Atlona flashed with the B&O firmware in order to get the hidden menu of having 2 screens. I know this first-hand. I had the switcher without the B&O firmware and it did not provide the menu until it was flashed with the B&O firmware. This is detected via HDMI.
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Sun, Jan 10 2021 7:52 AM
beojeff:
beoandy:
hi,
beoandy
hi beojeff!
very interesting, i use an original AT-HD4-V42 without b&o firmeware and it is recognized by the beosystem 4 at the hdmi output. thus I get the menu for the second monitor and the ir control via CTRL2 and for the projector via CTRL5. (as described in the manual BeoSystem 4 dual screen)
I also received this information from b&o and atlona support. (there is only one difference in the packaging) - where did you get the b&o firmeware did you flash it yourself or where was it done? (at that time I only made a firmware update from the atlona homepage version S99A)
thanks beoandy
beojeff
USA
Posts 2,012
beojeff replied on Sun, Jan 10 2021 12:23 PM
beoandy:
beojeff:
beoandy:
hi,
beoandy
hi beojeff!
thanks beoandy
It's possible that you might actually have the B&O firmware. Both B&O and Atlona advised that the switch needs the B&O firmware for it to be recognized. I sent mine to Atlona and they returned it to me after flashing it with the B&O firmware.
beojeff
USA
Posts 2,012
beojeff replied on Sun, Jan 10 2021 12:39 PM
beoandy:
beojeff:
beoandy:
hi,
beoandy
hi beojeff!
thanks beoandy
I had had extensive emails with BeoCare about this very issue. This is from one of their emails to me: One of our technicians just confirmed that it has to be the special B&O version of the Atlona splitter as this has different firmware installed. Unfortunately, it is not possible to use the non-B&O version."
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Sun, Jan 10 2021 1:35 PM
beojeff:
hi beojeff! very strange - as already written beocare and the support from atlona have confirmed it to me differently by email. beocare: "After looking int the matter, we are happy to let you know that there is no specialized B&O software available for the Atlona." and atlona: "the AT-HD4-V42-B & O has no special firmware, we suspect the difference was in the accessories back then, because a PUC cable with a 3.5mm connection can be used for the control from B&O TV." so i bought a used stock at-hd4-v42 on ebay and it works for me. (is recognized by the bs4 and i have the additional menu for two hdmi outputs, the timing menu for the cinema trigger for the cinema setup including ir control of the output switch of the atlona). beosystem 4 and the atlona switch have the last firmware.
beoandy
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Sun, Jan 10 2021 1:42 PM
beojeff:
hi beojeff! but that would be extremely luck if both have the b&o firmeware. back then i had bought two atlona AT-HD4-V42s from different retailers on ebay. both work.
beoandy
Page 1 of 1 (12 items) | RSS
