Beogram 1902 - Transportations screws
flydk
Posts 2
flydk Posted: Sat, Jul 20 2019 3:34 PM
Hi All
My girlfriend bought a Beogram 1902 for me as a gift.
In my eager to play my old records I didn´t see the label in the box telling my to remove the transportation screws before use Crying
Are the srews the three I see when I remove the plate`? the manual seems to describe them as adjustment screws to alignment? If it is these three - then they are totally stuck.
Can that be due to my "early" use?
Hope for your kind help
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Jul 20 2019 5:33 PM
They are fairly large headed - with chamfered edges if I remember correctly.
And you don't remove them - just losen them as far as they will go.
The suspension should then be moving freely when the platter is installed back.
Don't touch the deck height setting screws.
flydk
Posts 2
flydk replied on Sat, Jul 20 2019 6:34 PM
Thank you for your reply and help.
now I understand why it was so difficult to loosen the three alignment screws. So you happen to know where the screws then are located?
Kind regards
Page 1 of 1 (3 items) | RSS
