Is there a way to connect a BeoGram 6500 directly to a B&O multiroom wireless network and without the BeoMaster 6500?
This post has 6 Replies | 3 Followers
bonbazar
Posts 9
bonbazar Posted: Wed, Jul 31 2019 5:54 AM
Hello!
I am trying to do something that seems impossible... I would like to connect a BeoGram 6500 & a BeoGram CD 6500 to my multiroom wireless network (+/- 6 pair of speakers). I bought a second-hand NL/ML converter and do not want to use the BeoMaster 6500, but connect straight away the Beogram's on the network. Is there a way to do it? Which type of cables and extra converters are necessary to do so? I am a bit loss...
The reason I want to by-pass the BeoMaster unit is that it is particularly heavy and I can not transport it easily (need to tak e a flight, etc.). Also, it is useless as all speakers are active and I don't listen to radios.
I would like to control the BeoGram's with the B&O mobile app.
Thanks,
Emmanuel
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hello Emmanuel,
Thanks for your enquiry
Please can you let me know which other wireless B&O products you have in the house, especially noting which ones will be in the same room as the Beogram 6500?  I can then help you to get these working together.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
bonbazar
Posts 9
bonbazar replied on Wed, Jul 31 2019 12:09 PM
Thanks Steve for your quick reply. In the same room as the Beogram CD/Phono, I will have a have Beolab 3 connected to a B&O Essence. In other rooms I have Multiroom Speakers (e.g. Beoplay M5, Beoplay A6 & Beolab 2 mainly). Hope it helps. Emmanuel
Posts 2,165
Hi Emmanuel,
Thanks for your reply.  playing the Beogram to any room wirelessly can be as simple as plugging it into the Line In sockets of the Essence via this cable:-
https://soundsheavenly.com/beogram-record-players/14-2244-beogram-to-non-bo-device-phono-pre-amp-receiver-amplifier-etc.html#/2-length-1m/60-grounding-internal_ground_link
Steve.
bonbazar
Posts 9
bonbazar replied on Wed, Jul 31 2019 1:14 PM
I want to be able to control the Beogram CD with the app...
Posts 2,165
Hi Emmanuel,
That is possible, but more complex.  You will need the Beomaster 6500, an ML/MCL converter and an ML/NL converter.
The other option is to use a Beosound Ouverture to connect the Beogram to, then you just need the ML/NL converter.
Please let me know if you need any help with cables for either of these options.
Steve.
DMacri
United States
Posts 881
DMacri replied on Thu, Jun 18 2020 9:49 PM
Makes perfect sense to me Stick out tongue
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Page 1 of 1 (7 items) | RSS
