Lee's S45 speaker
This post has 23 Replies | 2 Followers
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig Posted: Thu, Aug 1 2019 8:10 PM
This was delivered in the post today, usual issue.....cone seized solid in the coil.
Craig
Posts 2,040
Silver Member
Otherwise its in very good shape, coil measures up at 3.4 ohms, cone and rubber both in good condition, one can see that the issue is the magnet has shifted on the frame...been knocked I expect....doesn't show well in the picture but it is off to one side.
Craig
Posts 2,040
Silver Member
Clamped it in the vice and popped it apart, for me the most scary part of the exercise, once its separated out each part can be rubbed down and the old adhesive removed.
Craig
Posts 2,040
Silver Member
The magnet and its mating face on the frame cleaned up first prior to allying epoxy, need to be careful to put the magnet back in the same polarity.
Craig
Posts 2,040
Silver Member
This doesn't need to be dead centre on the frame, but the closer it is the better.....
Craig
Posts 2,040
Silver Member
The rear plate and core need to be cleaned up too, old adhesive removed....
Craig
Posts 2,040
Silver Member
And then they need epoxying together.....they need to be placed on a completely flat surface or the core floats around!
lee
chester uk
Posts 7
lee replied on Fri, Aug 2 2019 8:51 PM
Ooooh... glad someone knowledgeable is doing this :-D
thanks for updates craig
And for quick progress!
frugal audiophile
Craig
Posts 2,040
Silver Member
Dust cap lifted off with the assistance of the girlfriends hairdryer...….
Craig
Posts 2,040
Silver Member
When the epoxy has cured the base plate is held in a vice and the frame, magnet and coil are carefully lowered onto the upright core. then the "alignment jig" is fitted, a saucepan is useful to rest everything on
Craig
Posts 2,040
Silver Member
Adjusting the screws around the lower half of the jig secures it to the magnet, then looking through the dustcap one can adjust the upper row of screws to centre the core in the coil.....
Craig
Posts 2,040
Silver Member
This takes very little time and once happy epoxy is applied before opening a bottle of wine...….
lee
chester uk
Posts 7
lee replied on Sat, Aug 3 2019 11:16 AM
great work!
Any recommendation on wine for this repair :-)
frugal audiophile
lee
chester uk
Posts 7
lee replied on Sat, Aug 3 2019 11:17 AM
great work!
frugal audiophile
lee
chester uk
Posts 7
lee replied on Sat, Aug 3 2019 11:20 AM
Will be on the look for some stands for these I think... might have to make some since they are reasonably rare I think...
frugal audiophile
Beo_Jean
QC, Canada
Posts 334
Beo_Jean replied on Fri, Aug 23 2019 2:01 PM
No one can do this better than you Craig!
Now looking at how the old glue was applied; it tells a lot why the magnet shifted...
Keep filling the Workbench forum with exiting projects Craig!
lee
chester uk
Posts 7
lee replied on Sun, Aug 25 2019 9:47 AM
I have been listening to the speakers for a couple weeks now occasionally, seems no issues with them at all really.
I may now take some measures to stiffen the enclosures and recap, and check the resistors haven't caused heat damage.
and in background I now have to consider making some stands myself since these are so rare now.
I want to lift them 18in / 45cm from the ground over a low sideboard which I think is not possible with the original stands.
the low bass seems present but modern music with very low frequencies seems to be confused.
bass guitar and drums seem well reproduced though.
classical music really protrays well.
I think high treble could be improved with cap change, is there a kit for caps / resistors?
also the sockets for the speaker wires at the back are giving really quite a loose connection, I've not seen any common solution for this yet, can anyone help?
and thanks again to Craig... Yes - thumbs up
frugal audiophile
Craig
Posts 2,040
Silver Member
Craig replied on Tue, Aug 27 2019 11:19 AM
Beo_Jean:
Charles
Thats very kind of you to say....I am keeping an eye open for another BG4000 in need of repair, friend of mine is quite taken with mine (and withb good reason Smile)
hmj
Posts 7
hmj replied on Fri, Dec 17 2021 2:04 PM
Craig:
Just received a pair of these and one of the bass units have suffered the same fate. Reading 3.4 ohms across the coil so I'm hoping it can be fixed? I've read several threads here on the topic, which leads me to this question? Am i right in thinking it's just the strength of the magnet holding the motor system together? Hence you have to prise them apart? Cheers.
Craig
Posts 2,040
Silver Member
Craig replied on Mon, Dec 20 2021 6:31 AM
The magnet, core that sits inside and the top plate are all glued together during manufacture.....the glue gets tired over the years and fails, follow the post and carefully pull the magnet from the frame.....
styppen
Slovenia
Posts 86
styppen replied on Mon, Dec 20 2021 6:37 AM
I have a pair extra. Let me know if you're interested.
hmj
Posts 7
hmj replied on Mon, Dec 20 2021 7:03 AM
styppen:
What are you asking for them?
hmj
Posts 7
hmj replied on Mon, Dec 20 2021 7:31 AM
Craig:
Thanks Craig I had a little play over the weekend and managed to separate everything. Will be cleaning them up today and re-gluing following your thread. Without a Jig I'm racking my brain how to align the centre cone accurately.
Craig
Posts 2,040
Silver Member
Craig replied on Mon, Dec 20 2021 4:00 PM
I have tried a couple of different methods....none have worked as well as the jig method, its not difficult to make one from a section of plastic pipe ;¬) I can post a few pics if you like?
Craig
Page 1 of 1 (24 items) | RSS
DigiCert Secured Site Seal
