Loud clicks at startup of Beomaster 7000
hermflink
Posts 1
Silver Member
hermflink Posted: Sun, Aug 18 2019 9:42 PM
Hi All,
Since a few weeks, my Beomaster 7000 has loud clicks over the speakers when powering on from standby by selecting an input. I noticed the mute relay clicking at the same time as the power relay. Normally, I would expect the muting relay to activate a few seconds after powering up when voltages are stable (to protect the speakers, right?).
I measured spikes of 3V on the speaker output during startup and also sometimes when switching mute on/off. Don't want to damage my speakers.
Inside, I found the mute relay being a black component instead of the transparant version I see in links like https://archivedforum2.beoworld.org/forums/t/255.aspx?PageIndex=1, so I would expect it has been replaced before (bought mine ten years ago, don't know what the previous owner serviced).
The caps look original, as far as I can determine. Would this sypmtom indicate recapping the BM?
Also, my remote Beolink 1000 in not always responsive. Cleaned the dust from the IR leds, but to no effect.
I am up to this job, would love to learn from it, and the link above already made me anxious to step in.
Please advice, many thanks in advance.
Regards,
Herm
Page 1 of 1 (1 items) | RSS
