Sound Playback Issue - Low voice
This post has 9 Replies | 0 Followers
athlon007
Posts 9
athlon007 Posted: Mon, Aug 19 2019 11:08 AM
Hello,
I have the following set up.
Beovision 4-65
Beosystem 3
1 BeoLab 7-1
2 BeoLab 3
2 BeoLab 6000
I am playing back a BluRay via the HDMI connected Samsung BD8900. this is set up via DTV connection
The issue I am facing is that sometimes the voice playback is really really quiet. When I click on the remote the TV button then back to the DTV button, the voices are ok again. I have set up the speakers multiple times and all is ok when doing the test.
Any help would be great.
Thanks a lot,
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Mon, Aug 19 2019 3:05 PM
How did you connect the speakers,- Roles?
athlon007
Posts 9
athlon007 replied on Wed, Aug 21 2019 12:04 PM
Hi Beovox141
The setup is currently
Beolab2
Beolab2
Beolab4
None
None
Beolab6000
None
Beolab4
Beolab6000
None
None
None
Is this what you mean?
Funktion TV
Subwoofer
Subwoofer
Left Front
Left Surround
Right Front
Right Surround
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Wed, Aug 21 2019 4:16 PM
Not exactly, but never mind.
Go into the sound menu, what does it say under Sound system.
Are you danish by any chance ?  (Funktion TV)
athlon007
Posts 9
athlon007 replied on Fri, Aug 30 2019 7:49 AM
Hi, no I am Swiss :-)
Today again it happened. I turn on the BO 65 to DTV then turn on the Samsung BD player. I play the movie and the voices are not there. I switch to TV and then back to DTV and voices are there. This just cant be normal.
This is what it says under Sound System
PCM 2.0
Dolby Pro Logic IIx Movie
Speaker 5
athlon007
Posts 9
athlon007 replied on Thu, Sep 12 2019 2:02 PM
I really would be grateful for any help. It can't be that such an expensive system, has this issue?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Sep 12 2019 6:42 PM
How is the BD8900 set to output a sound format? It should output PCM multichannel through HDMI
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, Sep 13 2019 12:00 PM
if you have set the speaker value to '5' there's a speker missing: Where's your center speaker??? The voices will be mostly played via the center speaker.
If you don't want a center speaker you can select 'Speaker 4' to get the voices back. If you select 'Speaker 1' you will hear nothing if no center speaker connected and defined. Wink
Ralph-Marcus
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Sep 13 2019 12:31 PM
BEOVOX141:
The BS3 doesn't have roles. Only with option AST enabled on the mk2 or newer versions, there is some kind of roles.
athlon007
Posts 9
athlon007 replied on Sun, Sep 15 2019 11:08 AM
Hi all, I have set the speakers to 5. I have the full speakers one in front  and two on the right and two in the back.
When first turn on tv and the BD player the PCM is set to 2 and no voice is heard (blu ray is set to PCM) Then when I click on TV and back to DTV, the PCM changes to 7.1 and voice is heard.
Really strange how come the voice is not heard at startup
Page 1 of 1 (10 items) | RSS
