Hi, I just bought used MS6000 with Beolink 1000 remote, but the remote is "Video Terminal" version (second one from left on the picture). Volume and channel switching works, but it doesn't have any "menu" or "shift" buttons, and from what I understand there is no way I could use it to tune channels or switch video source on my MS6000.
On technical specification it says that MS6000 was supplied with either Beo4 or Beolink 1000 remote. I just want to make sure that the newer version of Beolink 1000 (Mk III, the last one on the right) would finally work and support all functions (menu, tuning, switching sources etc).
