Hi I need some advice about my beloved Beocenter 1 it’s currently on the large pole stand. But I need it to go on a tv cabinet so it needs to be as low as possible. I have seen pictures of one that seems to just be sitting on the base which is what I need. Now do I need to get a new stand,if so where from I’ve looked but can’t find one in the UK, or can I modify my current stand? Many thanks
Richie
Hi Richie,
there is a table stand. That‘s probably the one you are looking for. I unfortunately only have a new floor stand, which I would consider selling.
Cheers,
Kai
