Do you know how to activate the new control menu on the ATV where you can switch user and hibernate?
On the Apple remote it is a long press in the TV button. What is this on the BeoRemote if possible?
ibg001:Do you know how to activate the new control menu on the ATV where you can switch user and hibernate? On the Apple remote it is a long press in the TV button. What is this on the BeoRemote if possible?
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
It is very simple (when you know how to...)
Just press the yellow button for a few seconds and the AirPlay menu will appear.
Millemissen:It is very simple (when you know how to...) Just press the yellow button for a few seconds and the AirPlay menu will appear. MM There is a tv - and there is a BV.
Oups! - that one....never missed it.
Seems that we need help from the guys, who wrote the new PUC.
Frederic:I have the same issue, ATV 4 turns back on. Why ? Tried everything (turninh HDMI- CEC off, airplay off, ,,,) something in the newer tvs must maybe sent over hdmi from time to time turning atv on. I put some heat sinks on it. D'ont care anymore
I was more if the control menu is available with the PUC setup. So no mapping for the long press for the button. B&o could easy have put this in the list menu on BeoRemote One where the AirPlay menu already is.
Hi Fl_ip
Can you find which button is mapped to the Apple TV button and long press that gives the new Control menu?
ibg001: Do you know how to activate the new control menu on the ATV where you can switch user and hibernate? On the Apple remote it is a long press in the TV button. What is this on the BeoRemote if possible?
Anyone?
How did you manage to get the new menu? Where you can switch users etc? Long press on the TV on the Apple Remote does this. But the new PUC dissent have this option?
Why update ATV. What do you get, besides trouble ?
In regards to what version Mr Pan?
Anyone else noticed that the "Apple Remote 4th gen from OS13" PUC for the Apple TV 4K has disappeared from the PUC database?
It's PIA because the Apple TV keeps on streaming even when I put my BV14 into standby... Apple TV refuses to go into stand-by. And yes... it's configured the right way un the PUC settings of the connection.
