Moment Chromecast
Andrewharvey
Posts 37
Andrewharvey Posted: Sun, Oct 6 2019 8:27 PM
Is it possible to connect a Google Chromecast device via the RJ45 connector to get the device to accept Chromecast connection?
Millemissen
Flensborg, Denmark
Posts 14,680
Andrewharvey:
You can connect a Chromecast device to the BS Moment just like you can connect any other external device with an analog (R/L) output.
That is what the ‘Line In’ input on the Moment is for.
If you - by the RJ45 connector - mean the 2 PowerLink outputs (called Speakers)....no these are for the BeoLab speakers.
And the other RJ45 connector is for a network cable for connecting to the home network (ethernet).
Andrewharvey
Posts 37
I have the B&O supplied cd drive connected through the line input
I was hoping to connect the chromcast via the network connector
If ths is a bad idea i guess i will need a splitter switch to allow cd playback or chromcast
Millemissen
Flensborg, Denmark
Posts 14,680
It is not just a bad idea, it won’t work!
You will need the switch in your case.
andy_js
Englandshire
Posts 223
andy_js replied on Mon, Oct 7 2019 4:54 PM
I'm surprised B&O haven't added Chromecast support to the Moment in an update.
laseralex
Posts 240
laseralex replied on Thu, Oct 10 2019 12:00 AM
andy_js:
I assume the processor doesn't have the required horsepower, or they would have done it already.  They obviously know how to integrate the SDK, since they have already done it in numerous other devices.
I'm less interested in adding Chromecast than adding Google Voice support for the existing Deezer/Tunein/DLNA streaming.  I find the B&O Multiroom to work better than Chomrecast anyway.  (Faster startup, add and subtract rooms at will.)
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Oct 10 2019 9:48 AM
laseralex:
Maybe derailing the thread but just want to clarify:
Supporting e.g Deezer or TuneIn in Google Assitant is nothing B&O are involved in. That is between google and the service.
Agree that B&O multi room is superior to fiddling with Chromecast for the same.
Page 1 of 1 (7 items) | RSS
