Hi, i try to connect Android Box to BV7-32. I connect video through DVI ( HDMI to DVI cabel) but I am unable to get sound from device? Box have only analog audio out through 3.5mm jack. I have 3.5mm to RCA jack cable. As Box input I select AV1 and VMEM as source. But unable to indicate audio input. There is only A1-A4 digital input as choice and seem no analog inputs. Any help 🥺?
You should be able to connect audio via scart (av1)while using DVI for video, so get an adapter scart>cinch and a cable cinch>minijack.
