Hi B+O specialists
I bought a pair of BL8000 : One with a brumm , but otherwise ok, one with no light.
i opened the BL 8000 with no light : Powerunit arround little transformer showed print overheated ,cupperline loose from print.
action : exchange powerunit from loudsp1 to loudsp.2, after this action loudsp 2 works fine , greenlight, music plays clear . after disconnecting source loudsp 2 gos from on to standby and vice versa on a constant base.
I can hear the relais switching on/off.
Does somebody knows , where to search for the trouble and knows a solution?
Thanks for a reply
Ueli out of Switzerland
