i thought i'm a luky guy, cause i bought a BL5000 in mint condition for very small money. My old one has the typical display problems with pixel errors...
The display from the new one works fine, but when i setup her in the two way mode, the "no contact" error is displayed... My BM4500 works fine in two way, i tested the old one BL5000 -> working in two way. I tested also with my BL7000 -> working in two way.
so it seems that the new BL5000 has a two way problem :-( never heard about a "no contact" problem with a BL5000! This problem is typical for BL7000...
Any ideas or suggestions?
Thanks in forward
Michael
Hi, i found this post: https://archivedforum2.beoworld.org/forums/t/9016.aspx?PageIndex=5
i think that is the solution :-) winter is coming and i will order new capicitors...
Thx
