Hello all,
I am searching for the main switch from Beomaster 1600 T1703. Guess that similar can be found in Beomaster 1700. Please drop me a message if you have a spare one by chance.
Best
These switches can typically be repaired.Give it a shot of contact cleaner, work it a couple of times and tighten the spring on the side a bit.
Hi Martin,
yes. I did that and it worked. Unfortunately, while assembling it back again, I used a superglue which leaked inside the switch, breaking it once for good ;/
