RJ45/PL and the MCL2P as an amp?
This post has 9 Replies | 1 Follower
Millemissen
Flensborg, Denmark
Posts 14,680
Millemissen Posted: Fri, Oct 25 2019 10:54 PM
Anyone used the (MCL)2P to drive passive speakers, when connected to a tv with RJ45/PL outputs?
Something to consider besides using the fully wired PL cables???
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi MM,
B&O TVs and audio products since 2013 (with RJ45 PL sockets) don't provide a trigger voltage for pin 1 of the Powerlink plug, only pin 4.  This means that they can't trigger a Beolink Passive or MCL2P correctly via a normal (fully wired) RJ45 to Powerlink cable.
Instead, please use this modified version of the cable when triggering a Passive or MCL2P:-
https://soundsheavenly.com/playmaker-and-essence-wireless-streaming/72-388-playmaker-rj45-to-beolink-passive-ml-mcl-converter-mcl2p.html#/9-length-18m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks Steve - I had something like that in the back of my head.
However, I did set up a MCL2P using a adapter (RJ45 to DIN PL) and a fully wired (DIN) PL cable and it triggered the 2P.
With the Passive/the ML/MCL Converter version I had no luck....it refused to trigger the amp.
What I was worried about was, that - even when the speakers played just fine - there was a message in the soundmenu of the tv saying ‘missing’ flashing.
I’ll have to return to that setup anyway, because I wanted to bring a second 2P (for driving the surround channel speakers).
I just wanted to be sure not having to return a third time.
As I wrote, the tv (an Avant/2015 model) is able to trigger the 2P.....the speakers played as I left the place.
Any further comments?
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Oct 26 2019 5:25 PM
^ Interesting discussion.
Question for MM - when using the MCL2P in this way, does the 'mute' function work OK?  (I vaguely recall having Muting (rather than 'trigger') problems using an MCL2P in the distant past, but I can't remember what cables I used!).
Posts 2,165
Hi Guy,
The Mute function won't work this way, you would need to turn down the volume instead of muting the amp (it is the Mute output that is missing from recent B&O master products, starting with Beomaster 5 from 2013 onwards).
All versions of MCL2P, Beolink Converter and Beolink Passive will work with the modified cable that I mentioned above.  Some later Beolink Passives will work on a standard (fully wired) RJ45 to Powerlink cable, but the operation may be unpredictable after they have been turned on and off several times.
Steve.
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks Steve,
I guess he guy - who I helped - will have to re-think his project.
Millemissen
Flensborg, Denmark
Posts 14,680
Anyone with a personal experience with this kind of setup?
Millemissen
Flensborg, Denmark
Posts 14,680
I’ll have to dig into this once more....Steve and others.
Since the cables are already in place, it would be a pia to have to replace these with the ones that he could buy from SoundsHeavenly.
However, talking to different persons I hear different versions of what has to be changed at the plugs.
Some say 1 and 4, others say 4 and 7 has to be short-cicuited.........I am quite confused.
I guess it would be best to replace the DIN plug at one end with a Rj45 connector in order to eliminate the now used adapter and resolder (?) at the DIN plug at the other end (where the 2P is).
I see this in the Beolink Handbook v 1.9
Posts 2,165
Hi MM,
Please drop me a PM or direct email and I can help you to get this sorted out.
Steve.
Millemissen
Flensborg, Denmark
Posts 14,680
Direct mail send!
Page 1 of 1 (10 items) | RSS
