Beogram 1700
James1980
Posts 80
James1980 Posted: Tue, Oct 29 2019 11:42 AM
Hi all, I have a Beogram 1700 that has started to behave strangely I would say, hoping that an expert on here may be able to point me in the correct direction before it’s laid to rest.. periodically for the past couple of months it has randomly sped up from 33 to 45 on its own and pressing pause has caused the needle to lift and then move erratically. Came to switch it on today and as soon as it is plugged in it spins up to 45, and none of the buttons are responsive at all. Can anyone help please?
thanks in advance
James
Beovision 10, Beoplay V1, Beolab 17, Beolab 9, Beolab 4,  Beosound 2, Beosound Moment x 2,  Beoplay M3, Beogram 1700
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Oct 29 2019 4:05 PM
Cracked solder joints.
Bad speed setting trimmers.
Bad belt.
Possibly also oxidated contacts or something spilt into the operation panel.
When it acts up, carefully guide the the tonearm to where the end-groove of a record would be and see if it will
do it's end-of record routine and stop.
Page 1 of 1 (2 items) | RSS
