Have you tried connecting the phono pre-amp output to one of the inputs on the Denon other than the phono input? If the Denon has a phono input, you wouldn't want to plug the phono pre-amp output into it, as the signal level is going to be too high and you'd be applying the RIAA equalization twice.
You should try another input like CD or Tape or Aux, etc. and see if there's any output.
Does the Denon have any proper output to the speakers with other sources?
Hi Bill
Thanks for getting back to me. I’ve tried every port on the Denon and put the amp to AUX and PHONO as well. My record player plugs in and works absolutely fine that’s why im at a bit of a loss. Especially when AV Services called me to say there was nothing wrong at all with it all I was missing was a pre amp.
Sorry if the picture isn’t great I’m doing this off my phone and copy pasting the image but this is
all the inputs on the back of the amp and none work
Hi, nothing was uploaded. I'm sorry that you're having troubles. If the technician said your BG5000 is good, then there are a couples of things to check. First, there may be a cable problem with the adapter you're using to connect to the preamp. also, you will need to test some other device in your Denon to make sure it is working correctly.
Bill
