Beocenter 9000 - volume touch panel problem
Pinio
Poland
Posts 2
Pinio Posted: Mon, Nov 4 2019 3:27 PM
Hi everyone.
I bought BC9000 and unfortunately the volume touch panel does not work. Its very strange becouse, once in 50 times will work.
Everything else works great.
I read that I can reset the memory NVRAM. Can anyone describe to me step by step how to do it. I didn't find it in Service Manual.
Maybe someone have other solution for me.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Nov 4 2019 5:53 PM
The most likely cause is that the glass panel is becoming lose as they will almost all be by now. In that case have it fixed.
Or - if it was already fixed, then it's often seen that too thick tape was used to fix it, thus not providing sufficient contact pressure to the underlying circuitboard.
Try using a little more (though still "controlled") finger-force when operating it, - if that makes it work the above diagnose is confirmed.
Pinio
Poland
Posts 2
Pinio replied on Tue, Nov 5 2019 8:09 AM
You have absolutely right :) When i try press touch panel harder than volume up/down works good. But i have to really hard press.
I ordered remote controller Beolink 1000 - and i will using as default for volume up and down.
Please confirm that Beolink 1000 is compatibile with my BC9000.
I have Beomester 3000 too, but souds from BC 9000 its mutch better than Beomaster. It s really fantastic sounds.
My BC9000 works with Beovox S45-2.
Many thanks for help.
Page 1 of 1 (3 items) | RSS
