EDIT: Beogram 4002: speed problem at 45rpm after new belt (Dutch)
This post has 11 Replies | 3 Followers
MartijnQuirijns
Posts 8
MartijnQuirijns Posted: Sat, Nov 9 2019 11:10 AM
EDIT: Okay guys, even with manuals and technical schedules I can't get the problem solved.This is beyond or above my knowledge. If anyone knows a good Beogram specialist in Amsterdam (or surroundings) I would like to get his or her name. Thanks in advance, kind regards, Martijn
Dear people of the forum,
As my Beogram 4002 started to slow down in rpm I thought a new belt would help. But strange enough it seems even slower now at 45RPM. Playing at 33RPM seems okay.
Is anyone familiar with this problem? Answers are welcome, also in my native language Dutch ;-)
Martijn
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig replied on Sat, Nov 9 2019 5:02 PM
Have you tried to adjust the speed potentiometer for the 45rpm speed? its located on the circuit board inside?
Craig
MartijnQuirijns
Posts 8
Thanks for your answer Craig. I'll Google (or Youtube) a bit to be sure where this potentiometer exactly is, but thanks for this tip!
Regards,
Martijn
Craig
Posts 2,040
Silver Member
Craig replied on Sun, Nov 10 2019 5:58 AM
Become a silver member and you will have access to the service manuals to help you 😉
Craig
Posts 2,040
Silver Member
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Nov 10 2019 7:14 AM
The new belt is tighter.
Either the motor needs a very thorough service or the new belt has wrong elasticity and/or size and will eventully cause permanent damage to the motor bearings (if bought off Ebay this is very likely).
MartijnQuirijns
Posts 8
Thanks for your answers guys! In the meanwhile the platter is spinning again, but I the 45RPM speed problem maintains. My own manual is somewhere in a box in a depot, so maybe I should start searching it ;-)
rajeegeorge
Posts 4
Hi Martijn
How are you this not an answer for your question, rather I need you expertise on a schematic written in Dutch kindly translate it to English. I hope you got an answer if not good luck.
Thanks in advance
MartijnQuirijns
Posts 8
I ca try, just sent me what you have...
Regards
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Mon, Apr 27 2020 4:25 PM
Afgezien van de potmeters is het relais een zwak punt.
Dat relais schakelt op een bijzondere wijze en zijn niet nieuw meer te krijgen. Een vervanger is er niet voor.
Ik heb een alternatief relais samengesteld uit een klein SMD relais op een converterboardje. Dat komt dan op de plaats van het originele relais. Dat werkt als een speer. Het is niet gegarandeerd dat het de oplossing is, want ik kan uiteraard op afstand ook niet zien wat er inmiddels mee gebeurd is.
Maar als je niet een goede snaar hebt besteld en, zoals Dillen al aangeeft, er eentje is die via eBay is gekocht, dan heb je waarschijnlijk een veel te strakke snaar waardoor de tafel niet op snelheid kan komen.
De motor kan ook nog de oorzaak zijn en soms moet deze uit elkaar.
MartijnQuirijns
Posts 8
Apart from the potentiometers, the relay is a weak point.
That relay switches in a special way and is no longer available. There is no substitute for it.
I have composed an alternative relay from a small SMD relay on a converter board. This will replace the original relay. That works like a rocket. It is not guaranteed that it is the solution, because of course I cannot see remotely what has happened to it.
But if you have not ordered a good string and, as Dillen has pointed out, there is one that has been bought through eBay, then you probably have a much too tight string that prevents the table from getting up to speed.
The engine can also be the cause and sometimes it has to break up.
rajeegeorge
Posts 4
Hi this is my email kindly contact for the circuit diagram for translation
rajee20042001@yahoo.com
Thank you
George
Page 1 of 1 (12 items) | RSS
