Beogram 2200 Turntable
This post has 3 Replies | 0 Followers
ouverture
London
Posts 263
ouverture Posted: Tue, Dec 11 2012 5:47 PM
I need to get a new catridge/sylus for my Beogram 2200, the old one is a model MMC 20 E
but would any of these below be OK ??
http://www.beoworld.org/prod_details.asp?pid=727
or preferred for that matter !
it looks like the MMC 20 S and the MMC 20 CL are the most expensive / sought after, are they really that much better, should I pay extra for one of those, providing I can even find one of course
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Dec 11 2012 8:33 PM
You can use any of the following:
MMC3000
MMC4000
MMC5000
MMC6000
MMC10E
MMC20S
MMC20E
MMC20EN
MMC20CL
SP15
The best is the CL, with the EN being the next best of the 20 series. However the alternative,  if you have an old cartridge which is worn, is to get Axel to fit a new stylus assembly. That way you can have anything you want! I have a MMC20S fitted with a Shibata diamond which makes it the equivalent of a MMC5000. The 20S is the least specified of the 20 range. S stands for Spherical, E for elliptical, EN for Elliptical Nude and CL for Contact Line.
Peter
ouverture
London
Posts 263
ouverture replied on Tue, Dec 11 2012 9:32 PM
Peter, thanks for that timely reply, the hunt is on !
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Dec 11 2012 9:53 PM
Just to add, in case it helps you to decide... 20S and 20E (and I suppose 10E as well) are black, while the others are silver Big Smile
--mika
Page 1 of 1 (4 items) | RSS
