Hello,
i just have a beovision LX 2500 with what i think is the remote beolink 1000 mk3 (with "AV" button at the bottom left side).
I would like to connect a dvd player or the PS3 using the scart but i cant access to the AV/aux video.
I light on the television with "TV" button, i can select any channel but the "AV" button doesnt do anything. I tried "shift" then "tv", it write "AUX -" on screen; if i do it several times it writes "AUX 1" on screen but nothing happened. I also tried "V-tape", "record" with or without combination of "Shift" but nothing happened.
What can i try ? Maybe a reboot of the remote'configuration but i didnt find anything.
Of course i tried to switch on the tv then the DVD player for automatic launching but i didnt work too.
Sorry for my bad english
Max
Deleted because it took several hours to be 'approved' by the strange Beoworld 'post-policing-system-, and then appeared, by which time I had already repeated my input below. This is very frustrating!
Hi and welcome to Beoworld!
Try going into the setup menu and changing the input settings.
Press Menu (or SHIFT TEXT) and scroll right using >>. If you change anything store using the STORE button twice.
You should be able to select the SCART input using V.TAPE or SHIFT V.TAPE, but (depending on settings) SHIFT TV may work, because this should be the same as VIDEO AUX.
(B&O equipment does not use the AV button to select an input - it is used for other functions!)
Shift-TV-2 if I remember correctly.
Thank you both of you !!!!
I really spent hours before posting on beoforum and you solved my problem in half an hour. I used the Shift-tv-2 and it worked !!!
I will change the setup later.
Thanks again !
