Dear friends of Beoworld!After the last BV Avant NG Update also the remote 1 should get an update
this starts after turning off the TV - but I always get an error - after some percent the remote tells failure and stops updating with a reboot
is there another way to get the update? Do I need to contact the dealer?
thanks and best regards Elmar
I have a BeoRemote One BT living outside of the B&O ecosystem and wondered how it should be updated too?
In what way is it 'better' after such an update?I don't quite feel the need to update it, it is doing perfectly fine as it is..
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
