Did you try the XML available here on the forum?
Maybe generic commands like on/off, channel +/-, volume etc… remains the same for all range.At least it did work for me. I use a Samsung XML not related with my Samsung TV but all commands do still work as expected.
Can't find it right now, but searching Samsung + XML you should find something. If i remember well they should be at least classic TV and Smart TV. Tell us if it worked !
Try https://archivedforum2.beoworld.org/forums/t/4021.aspx
Paul
Thanks I gave the file to a B&O dealer, I'll keep you guys up to date
