Since they look the same, can you change their purpose by uploading firmware?
Here is the BLGW:
And here an older version of the BLC NL/ML:
And the latest Version of the BLC NL/ML:
I want to play with a BLGW to see how the Beosound 5 can be controlled via iPad App Beolink 2.
Instead of buying a used BLGW I could temporarily turn a spare BLC NL/ML into a BLGW - that is my idea behind the question...
Thanks for your Input!
Ralf
Any ideas / hints for me?
kallasr: Since they look the same, can you change their purpose by uploading firmware? Here is the BLGW: And here an older version of the BLC NL/ML: And the latest Version of the BLC NL/ML: I want to play with a BLGW to see how the Beosound 5 can be controlled via iPad App Beolink 2. Instead of buying a used BLGW I could temporarily turn a spare BLC NL/ML into a BLGW - that is my idea behind the question... Thanks for your Input! Ralf
both BLC are exactly the same. Just strip away the plastics strips on the BLC without AUX. You'll see the AUX connections are present.
Same on the other side of this BLC
Note: even the BLGW have them!
Thanks. I thought so About the BLCs, too.
But how about the Beolink Gateway?
It does look the same as well. So only a Software issue e.g. you Can Change a converter to a Gateway (and vice versa)?
kallasr:Thanks. I thought so About the BLCs, too. But how about the Beolink Gateway? It does look the same as well. So only a Software issue e.g. you Can Change a converter to a Gateway (and vice versa)? Ralf Living Room: Beosystem 4, Beolab 7-6 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), no Subwoofer. Screen: Panasonic TX-P65STW60 Home Cinema: Beosystem 4, Beolab 7-2 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55 Home Office: Beovision 10-40 on STB Bracket wall mount masterlinked to Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all white, wall-mounted) In storage: Beolab 5000/Beomaster 5000 (1960s).
Carolpa:Just strip away the plastics strips on the BLC without AUX. You'll see the AUX connections are present. Same on the other side of this BLC
Hi Ralf
I do not know if this answers you'r question but I once bought a BLGW at a discount from a dealer because it was a BLC NL/ML body with BLGW software on it. The dealer had received it that way from B&O and had intended to sent it back to B&O but then sold it to me as I was looking for a used BLGW. The problem I had with it was that the software would not update, and after contacting B&O they told me that it would not update as it was essentially a BLC NL/ML. I sent it back to the dealer in the end and the dealer sold me a new BLGW at a good discount.
Hope this helps
Huw
Hi Ralf, were you able to find a way to change the firmware? I found the latest firmware for the BLGW online, just need a way to upload it to the NL/ML converter! Rob.
You refer to the file 1.4.0.20048-signed.bin.zip?
I got this as well but never tried to upgrade the spare converter...
Bought a used MLGW but was not satified so I gave up on B&O home Automation for now.
Hi Ralf, I am thinking of getting a used MLGW too, what is it you don't like about it? Regards, Rob.
ebnrob: Hi Ralf, I am thinking of getting a used MLGW too, what is it you don't like about it? Regards, Rob.
ebnrob: kallasr: Since they look the same, can you change their purpose by uploading firmware? Hi Ralf, were you able to find a way to change the firmware? I found the latest firmware for the BLGW online, just need a way to upload it to the NL/ML converter! Rob.
is there already a solutions to upload the BLGW Firmware to a NL/ML Converter? I have one spare and would love to experiment with a BLGW.
Living room: BeoVision 7 MKV + BeoLab 7-2 + 2x BeoLab 8000 + BeoLab 2 + 2x BeoLab 4000Office / guest room: BV 7-32 MKIV / BL7-1; BeoSound Core + TurntableKitchen: BeoPlay M3Bathroom: Gira Radio + BeoLab CelestialEntrance: BeoPlay M3
