Beocenter 2200
RM1999
Posts 4
RM1999 Posted: Thu, Nov 14 2019 3:45 PM
Hi all,
I recently bought a Beocenter 2200 with a pair S45's.
But of all 4 sound exits (front and rear), does the left one function. What could be the problem?
RM
solderon29
U.K.West Midlands
Posts 764
solderon29 replied on Fri, Nov 15 2019 10:44 AM
The Beocenter 2200 doesn't have front and rear speaker facilities,simply stereo.There are speaker pair 1 and speaker pair 2 sockets.The second set are switched by a button at the front of the unit.
Your problem is probably due to a failed fuse.There is one for each channel,and they are located inside a little hatch in the base of the unit.You can see the hatch if you lift the unit,and I think there is a label to indicate the fuse rating too.
The combination of the Beocenter and S45 speaker's should work well.
Nick
RM1999
Posts 4
RM1999 replied on Fri, Nov 15 2019 1:13 PM
Which hatch do you mean?
RM1999
Posts 4
solderon29
U.K.West Midlands
Posts 764
Lift the unit at the front and tip it backwards.Along the righthand side edge you will see a section of the cabinet moulding held in by a small screw.Remove the screw and the moulding section(hatch) to reveal the fuses.
I've since checked the value,and they should be 2.5A slow blow types.
Nick
RM1999
Posts 4
RM1999 replied on Mon, Nov 18 2019 8:24 PM
It’s fixed. Changed the fuses and everything works fine!
solderon29
U.K.West Midlands
Posts 764
Goodo!
You should be able to get a user guide for the 'center,that will show you how to set up the record deck arm tracking weight etc,and the rcording possibilities etc.
You can connect a Bluetooth receiver to the tape copy socket at the front of the unit,to allow digital audio downloads from your 'phone or tablet too.
Nick
Page 1 of 1 (7 items) | RSS
