I would like to replace my 3404's cable connector that disconnects & plugs into the phono section.
It is female 5 pin din to 2 male rca plugs. I can't seem to find these. I have seen 7 pin versions. Will these work? here is the amazon link:
https://www.amazon.com/GLHONG-Adapter-Olufsen-Quad-Stereo-Systems/dp/B07VZMFJY4/ref=sr_1_6?keywords=din%2Bto%2Brca%2Badapter&qid=1576769338&sr=8-6&th=1
would these work?
thanks
I used your link and while on that listing did a search:
https://www.amazon.com/s?k=5+pin+DIN+to+RCA+adapter&ref=nb_sb_noss_2
And found a lot of 5 pin DIN to RCA, both female and male RCA, low cost plastic ones and more expensive metal/gold plated ones.
Jeff
