BLGW and Beosystem3
Michael
Atlanta
Posts 98
Michael Posted: Tue, Dec 31 2019 3:30 AM
I am setting up a BLGW with both NL and ML connections.
Things are going really well with the setup and macros except I can't seem to get any Beo4 commands through the BS3 to register on the BLGW.  All NL products are registering fine during capture.
is this a limitation of the BLGW/BS3 or an indication that something may not be set up properly?
Michael
Atlanta
Posts 98
Michael replied on Thu, Jan 2 2020 10:50 PM
Should of known better then to ask too broad a question on here over a holiday week;)
To clarify, my BS3 is the Video master and running the room speakers.
My NL/ML converter is Audio Master between my BS3 and a Moment.
Everything behaves well and I can send commands to the BS3 with the BLGW.
However, while capturing, it's all quiet from the BS3 (including Light commands) even though the BS3 is set to forward status and commands to ML.
I can however see some BS3 commands register on Network Link as they pass through my NL/ML converter.
I could use that to trigger macros somewhat but I was under the impression that more ML traffic would be visible on the Gateway.
Is that not the case or is my system just being flaky during setup?
Thanks.
Michael
Atlanta
Posts 98
Michael replied on Sat, Jan 4 2020 2:51 PM
Looks like I somehow missed this incredibly helpful document which has been referenced elsewhere on the forum:
http://mlgw.bang-olufsen.dk/source/documents/MLGW%20product%20compatibility.doc
Posting again for future readers.
Page 1 of 1 (3 items) | RSS
