Beomaster 6500 shows "locked" and does not work
This post has 2 Replies | 2 Followers
Balouou
Posts 1
Balouou Posted: Mon, Dec 17 2012 1:08 PM
Mein Beomaster 6500 tut ohne erkennbare Ursache nichts mehr und zeigt auf dem Display "locked".
Was kann man da machen?
Thomas
Norway
Posts 60
Thomas replied on Mon, Dec 17 2012 1:42 PM
if i recall correctly you can unlock it by pressing both right and left side buttons (lower area on the front) at the same time.
//Thomas
Format 0  😀😎
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Dec 17 2012 2:22 PM
Locked simply means that the tuner is locked to a station. It does not mean that the Beomaster is locked from use.
If the Beomaster does not respond to the remote control, try changing option.
The left and right buttons pressed simultaneously activates/deactivates the timer function.
Page 1 of 1 (3 items) | RSS
