Beolit 15 Only works while charging
noralexanian
Posts 2
noralexanian Posted: Wed, Jan 15 2020 8:40 PM
Just opened it from the box, charged it up, and then removed it from charged and it worked normally. But the next time I put it on charge, it would not work if it’s not charging. Even if I unplug it while it plays music, the speaker just turns off.
Any tips to fix this issue?
Pat
Posts 152
Pat replied on Thu, Jan 16 2020 8:11 AM
Try new battery
Jaffrey2230
Washington DC
Posts 520
Sounds like a bad battery. I had the same issue with an Arcam rCube back in the day. Just ended up using it as a connected speaker since the sound quality was good. In your case, since it is brand new you can probably get it replaced.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
noralexanian
Posts 2
The thing is that I opened the box after a month of receiving the speaker. Can I still return it? I ordered it on amazon
Jaffrey2230
Washington DC
Posts 520
In the US you have 30 days to return with Amazon. So as long as you start the process before 30 days...
B&O in my life 😊:
Page 1 of 1 (5 items) | RSS
