Beomaster 3000 Idle current in one channel not adjustable
Andreas
Germany
Posts 18
Andreas Posted: Fri, Jan 17 2020 12:08 AM
Hello everybody,
I changed the Trimmer and all caps on the board of an Beomaster 3000. All works fine... Sound plays in both channels, but I cant adjust the Idle Current on left side. I measure 20mA and it's not adjustable. The other side is not a problem.
What is the reason for this. Can anyone help me?
Thanks very much
Andreas
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jan 17 2020 6:53 AM
The resistors close to the trimmer (circuitwise) are known to go high in value.
That often causes situations like this.
Andreas
Germany
Posts 18
Andreas replied on Fri, Jan 17 2020 6:26 PM
Hi Martin, thank you for Tip. I measuer this weekend an post you results.
Have a nice weekend
Andreas
Andreas
Germany
Posts 18
Andreas replied on Sat, Jan 18 2020 5:53 PM
Hi Martin, I measured all resistors arround. They look fine. R 482 has 720 instead of 560. The others are in spec.
Another Idea of this issue? Thanks for help
Andreas
Dillen
Posts 13,191
Dillen replied on Sat, Jan 18 2020 6:08 PM
Replace resistors 480 and 482.
Andreas
Germany
Posts 18
Andreas replied on Mon, Jan 20 2020 5:53 PM
Hi Martin,
replaced and works. Thank you very much. You're great Smile
Andreas
Page 1 of 1 (6 items) | RSS
