Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Fantastic solution! There should be no issues with this because as you note there is no audio conversion being done by the iPad. You are really making great use of your BL 90 set up!
B&O in my life 😊:
seethroughyou:Can any of you foresee any problems or limitations using an iPad to USB in on the Beolab?
note: the shining dot is the optimal situation.
