BEOMASTER 5500 repair
Jaap van Oosten
Nederland
Posts 2
Jaap van Oosten Posted: Mon, Feb 24 2020 4:51 PM
Hello i am new to this forum,
I came in possession of a complete B&O system.
Sudden the Beomaster 5500 lost control with the remote control.
Also the front buttons did not function anymore.
Found the cause deep inside in the CPU unit a blown  1A F1 on-board fuse
D1 zener diode caused short circuit.
After  replacing the 5V6 zener it worked again.
I noted  Relay1  switching the 30V power for the output amplifier  have some sparking.
Strange that this power is not soft switching
some other weak point:
The response to the master control panel commands is slow  although the IR  level seems okay.
Another problem exists in the  BEOGRAM  6500
Starting to play a record the arm moves normal to the first position and moves down.
But the sound was weak and distorted  and  the stylus does not move it jumps back to the same groove
I inspected the arm the tracking system seems to function  the arm can move freely in its bearing
A very delicate system
The linear tracking motor does move when i carefully push the arm forward.
So the tracking system does work.
The needle looked okay  but i think maybe transport damage.
When i moved the 3 transport screws where fixed but the heavy disk plate was not removed i did not know it was loose
I have not seen the Beogram 6500 working in very long time it was just standing there since the owner died.
Those original cartridges are extreme expensive for just having it repaired an not much use.
I wonder if someone knows an alternative  for the BEOGRAM elements ?
Robert
Holland
Posts 204
Robert
Holland
Posts 204
Robert replied on Wed, Feb 26 2020 10:43 AM
BeoMaster 5500 has RIAA pre amp inside for the turntable
BeoMaster 6500 and 7000 not.
BeoGram 6500 and 7000 have RIAA pre amp inside
Jaap van Oosten
Nederland
Posts 2
thanks for reply
yes i saw the Riaa  correction circuit in the diagram
Another repair i did
The Amplifier got very hot at high volume and also hot just by the bias.
The bias power:
44V  0.2A per Power transistor    total 0.8A x 45V   about 35W bias power     ,   measured     45mV  over the 0.22
The cooling fan circuit 6  did not run  due  broken PCB traces
 Checked the NTC R50   >200k at room temperature drops when heated but the fan did not run at 40C
so i paralleled 100k with it to have the fan always running at low speed
that keeps the heathsink  cool
still the remote has a very slow response and sometimes the Beomaster starts up with max volume... good that i have no neighbors...
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Apr 9 2020 6:46 AM
Jaap van Oosten:
thanks for reply
The bias power:
Check - or replace - the backup battery.
Page 1 of 1 (5 items) | RSS
