By chance I found a document that deals with RS232 / HEX / PRONTO Codes (including many discrete codes) for LG TVs.
I am experimenting using my PRONTO Pro learning remote and my Beo5 and Beo6 remotes. So far, I have put the PRONTO Codes into the Pronto Remote and they all work with my LG B7 OLED this includes the discrete codes so for example ON on ly turns the TV on and OFF only off. There are discrete codes for the HDMI scokets so HDMI 1 goes direct to HDMI 1 etc.
My next task is to try to make an XML to get them into the BEO Configuration Tool to see if they work with that.
I have had to use VMWare to run Windows XP on my Windows 10 machine and m Pronto software and Beo Configuration Tool work brilliantly on there.
Stoobie
Link to LG PDF
