I am reprograming my BEO5 after having to put my BV5 in storage so am using an LG TV.
From the config tool I originally added the Humax PVR9200T but this is only able to be controlled through the PUC which i can not do now. How do i control the Humax through IR?
Do I need the humax HEX codes (if so does anyone have a copy).
Hope you can help.
Regards
Toby
Toby,
For DIRECT control without going via the PUC requires and XML control file to be made based on the IR codes either by capturing from the original remote control or find Pronto HEX codes on the web or converting the IR codes held in the PUC files.
I have converted the IR codes in the PUC file for the PVR9200T to a DIRECT XML file which is attached.
Just unzip the file to C:\ and it will automatically be placed in the correct directory of the B&O Configuration Tool.
When you click the OTHER tab in the product section of the configuration tool you will see it and you can drag-n-drop it into your configuration.
Regards Keith....
Thank you Keith you are a star
Hi Keith,
I have up loaded the file and installed it onto the Beo5. But I can not get it to control the Humax.
Any idea?
I think it was my error because I converted the 9200C rather than the 9200T as you had requested.
I checked the NEC code for each unit and the 9200T uses an address of HEX 00 and 9200C uses a HEX address of 11 which is why it did not work.
Attached is the converted PUC file for the 9200T
Thanks Keith,
Now just need to learn to use XML and make a few macros
