Beosound 3200
PM6
Posts 3
PM6 Posted: Mon, Dec 31 2012 1:57 PM
When I attempt to copy or play a cd to or from the hard disk my system intermittently switches to standby. There is no problem when playing the radio. This can happen at random time intervals sometimes within a few seconds or several minutes after of playing a cd or attempting to copy to the hard disk. Often I have to make several attempts to play or copy a cd from or to the hard disk to complete the process which is very annoying. Has anyone any ideas of the fault or know of a solution to this problem.Thanks
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
A Very Warm Welcome to Beoworld..
Has your Beosound 3200 previously worked without problems or is this unit new to you ?
If the problem has only recently been occuring, has there been any recent configuration changes particularly to the MasterLink ?
Regards Keith....
PM6
Posts 3
PM6 replied on Mon, Dec 31 2012 3:30 PM
Hi Keith thanks for the welcome. My system is approximately 12years old. This fault has been evident over a number of years on and off gradually increasing in frequency over time, which led me to initially suspect maybe a dry joint but having spoken to a B&O service representative who advised me to try changing the power cord which initially seemed to improve the situation I am now back where I started. Just wondered due to the intermittent nature of the fault whether anyone on the forum have experienced any similar problem before going to the considerable  expense of having to send to a B&O repair centre.
pf85
Posts 284
pf85 replied on Mon, Dec 31 2012 4:44 PM
You may download the service manual and check testmodes to see if an error code is stored. I am not a technician myself but an initial check can be done.
Keith Saunders
Posts 5,495
Is the Beosound 3200 standalone or is it connected to anything else ?
Regards Keith....
PM6
Posts 3
PM6 replied on Mon, Dec 31 2012 5:58 PM
My Beosound 3200 is wall mounted and connected to a pair of Beolab 6000 speakers Thanks
Page 1 of 1 (6 items) | RSS
