Beocord V8000 no picture
This post has 9 Replies | 1 Follower
lloydern
Posts 8
lloydern Posted: Tue, Mar 24 2020 7:58 PM
Hi!
I have a question about my Beocord V8000 which are connected to my Beovision Avant 32 DVD. Haven't used it for some years now, but tried to use it again this week.
The problem is this, I get sound, I get menu text and timecode etc, BUT NO PICTURE. Only a black screen. Everything is connected by the book.
How is this possible, any IDEAS??
Or is just the old machine broken of time spent down in my dry basement for 4 years....
Best regards Lloydern
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Mar 24 2020 9:33 PM
Just leave it running for several hours, with some old video tapes.  Eventually the heads will 'self-clean' and the picture will miraculously appear!  Or not Unsure
lloydern
Posts 8
lloydern replied on Wed, Mar 25 2020 11:36 AM
Thanks, I trying it out now. Will keep it running - Koronatime. Home all day long with the kids, so plenty of time. Hope this will fix the problem....
lloydern
Posts 8
lloydern replied on Thu, Mar 26 2020 10:23 AM
7 hours running but still now picture. But the screen has moved from all black to snowing. Is that a good sign??
Pat
Posts 152
Pat replied on Thu, Mar 26 2020 2:19 PM
Yes, the tape has reached non- recorded part, on the end Smile
Try another tape
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Mar 26 2020 3:36 PM
I seem to remember that some video tapes has a short 'cleaning' section at the start and/or end of the tape.  It could be worth repeat-playing these portions, or alternatively find a head cleaning tape.
There's a video about head cleaning here, it you fancy giving it a go: https://www.youtube.com/watch?v=0egTI__8D5E
Use at your own risk!
lloydern
Posts 8
lloydern replied on Fri, Mar 27 2020 12:12 PM
It is snowing all the time now, so its nothing to do with the tape itself.
Thanks for the tip about cleaning. I will chech it out....
Lloydern
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Mar 27 2020 2:11 PM
Just a couple of further thoughts:
How is the V8000 connected to the TV?  If with a SCART lead, have you ensured that the SCART plugs are pushed fully home, and maybe tried an alternative SCART lead to rule out a fault?
Also make sure that the lead is connected to the lower SCART socket on the V8000, marked 'AV'.
david707
Posts 146
david707 replied on Tue, May 19 2020 11:22 AM
I have exactly the same problem. Tried a different scart. All working fine until very recently and used a lot. Sound plays fine but no picture at all. Before the picture went there was a lot of interference, like a tracking error. The same tape played perfectly last time without tracking adjustment. Looks like an engineer job.
konrado
Posts 1
konrado replied on Fri, Nov 13 2020 7:42 PM
I have the same problem. Did anyone of you try the head cleaning tape? Did it work? Cheers, K
Page 1 of 1 (10 items) | RSS
