Hello,
I just linked a Mac mini on my Beovision 7, using a DVI to HDMI cable.
In order to get the sound from the mac, I have to use a jack to RCA. I seems that the entry right does not work anymore on the Beovision 7 (tried with multiple cables). As a result, only the left produces sound.
Is there a way to link it differently so both of the speaker work?
I thought of the entries A1 ; A2... Could it be a solution?
Thank you in advance!
Hi fsiprou, did you get it solved in the end? I'm trying something similar and I'm unable to get an audio through the A1, A2, A3 and A4 connections.
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
