airport express issue
This post has 10 Replies | 1 Follower
mivsbai
Posts 77
mivsbai Posted: Mon, Dec 31 2012 9:36 PM
Hi
I have just bought a airport express Generation 2. I have connect my beolab 3s directly to the AE, but the volume is too loud through this connection, even adjust the volume to the lowest level(next level down is mute).
Would this problem been fixed if i connect the AE to an external DAC with volume control through optical connection?
Many thanks
MartinW
Posts 389
MartinW replied on Mon, Dec 31 2012 10:13 PM
Sounds like the AE is on fixed volume output? It does work with a direct connection to the BL3's, you don't need another DAC
Millemissen
Flensborg, Denmark
Posts 14,680
But a good DAC would improve the sound Smile
Espescially if you listen to higher quality -files.
Greetings Millemissen
mivsbai
Posts 77
mivsbai replied on Mon, Dec 31 2012 10:23 PM
Hello martinw
Thanks for your reply, i do not mean the AE is  ot working with lab 3s. The current volume is not uncorformatable, but it is quite loud. Even i set the volume vey low, the result is still very loud. How can I change the fixed volume output into adjustable?
Many thanks
mivsbai
Posts 77
mivsbai replied on Mon, Dec 31 2012 10:25 PM
I need to make sure the AE's volume control can work with beolab 3s first, or I have to return it.
Millemissen
Flensborg, Denmark
Posts 14,680
Did you switch the input on the BL's to line-in???
Grrr! Millemissen
mivsbai
Posts 77
mivsbai replied on Mon, Dec 31 2012 10:43 PM
Yes, I did. I have done some online searching, the 2nd generation AE seems to have higher volume output level than the previous one. This might be the reason why the volume is loud.
mivsbai
Posts 77
mivsbai replied on Mon, Dec 31 2012 10:45 PM
I would not say the volume is at uncomfortable level, as I have a baby, even the lowest volume setting, it is still a bit too loud for my baby.
Klas Hesselman
Singapore
Posts 11
I recommend the Playmaker for these scenarios....i could never get a good solution with apple TV's, Airport expresses etc....got the playmaker a few months ago and I'm very happy with this
Chris Harrison
Peak District
Posts 381
What is the volume set to on the iPhone/ iPad/ mac etc you are trying to play music from? Have you tried turning that down too?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
fnrd1
Posts 1
fnrd1 replied on Mon, Jan 7 2013 8:13 PM
I had the same issue and put a short volume cable in between the airport express and ipod connector. For example: http://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH/ref=sr_1_2?ie=UTF8&qid=1357589241&sr=8-2&keywords=volume+control+ipod+cable
Probably not the best for sound quality etc. but it works for me.
Koert
Page 1 of 1 (11 items) | RSS
