I am struggling to find User Manual with information on the Timer mode of the BC9300... Can anyone offer any help with this... Tony
Have you tried here: https://www.bang-olufsen.com/en/product-support/sound-systems/beocenter-9000-9300-9500
Edit: Actually that's no use whatsoever! If you join this site as a Silver member the 9300 manual is available for download and has a section on the use of the timer.
Brilliant, thank you Guy...
