Beolab 5 in a non-B&O setup - Onkyo, AppleTV, Panasonic TV.
This post has 25 Replies | 3 Followers
Hugolainen
Posts 10
Hugolainen Posted: Wed, Jan 2 2013 8:48 PM
Dear All,
I have just bought four BeoLab 5 (2004) and are about to buy a Beolab 7-6 as center. I would like to use them both as a music system but as well connected to my 65" Panasonic TV and a receiver (which I haven´t bought yet) Thinking of the Onkyo 7or 8 series since it has an upscaling (which I need to get HDTV since I use Telia internet TV)
I want to connect Spotify, AppleTV, Blueray and DLNA for music which is actually controlled by the receiver.
I want to control the Beolab through my receiver since I control the sources from that. And I can control that from iphone and ipad.
When the receiver is switched on, the Beolab starts up. When I turn it off, the beolab shall turn off. Loudness should be controlled by the receiver. If I choose THX mode, that should go on. (Most likely an Onkyo question....)
Can anyone help me out how I should connect this,  please? I do not want to use Beolink but are after the design and great sound of Beolab 5.
I would also like to know if anyone have tried a wireless solution to the speakers that they can recommend?
Søren Mexico
Mexico City
Posts 6,411
Check the Onkyo line level output, before you buy it, I have an 708 and it cannot drive my BL 8000 to full volume, the line level for the 708 is 200 mV, it should be at least 400 mV.
Connecting active speakers to line will give you problems with the speakers turning on and of, when longer periods of silence is there, you will need a RCA and trigger connection to the Onkyo and this connection to a 8 pin din plug to the speakers. The trigger on the Onkyo is 12V, trigger to B&O speakers are 4.5V.
Hugolainen
Posts 10
Thank you! Seems like you know this! :-)
Do you have any suggestion of another receiver you think can be better where I will not experience this kind of problem?
Best !
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Jan 3 2013 11:28 AM
THIS might help
Ralf
bayerische
Ekenäs, Finland
Posts 4,770
Hmmmm, and that is a big HMMMM with the Beolab5's...
Using the beolab 5's this way would require a sound control to them... When you use the BL5's with third party equipment you are supposed to change the volume on the BL5's with your Beo4 (or other B&O remote) Line in will not change the volume properly.
But in this setup, you also have to have the Beolab5's connected to each other using the special "syncro" cable. Yours are early ones, just like mine, so I don't think they will work with the syncro cable. (Mine does not, even though there's electronics for it)
Syncro is meant to even out the sound if one of the speakers ir-eye misses an input change.
The Syncro cable is meant to be used with a stereo pair, but maybe someone can modify it to work with 4 speakers, and still keep the ohm setting in the cable, which is vital.
Too long to list....
bayerische
Ekenäs, Finland
Posts 4,770
To make things easier (a lot easier) buy a S/H Beosystem 3. All your problems solved. *Puff!*
bayerische
Ekenäs, Finland
Posts 4,770
Are you located in Finland BTW?
If so, where the heck did you find 4 Beolab 5's???
Hugolainen
Posts 10
Thank you! That was very helpful! Will review it more properly at the weekend!
Hugolainen
Posts 10
Hi, No, I am actually in Sweden. Haven´t bought them new (not in that financial stand yet) and there are quite a few for sale. So nothing strange about the 4 BL 5.
Hugolainen
Posts 10
bayerische:
Exactly in what way will everything be solved?
Maybe the Onkyo isn´t the best due to one of the answers in this thread? I am trying to get rid of all remote controls so am really interested in finding a way not to have to use those. Still - Beosystem 3 - how will that work with DD 5.1 and music? I am sorry, I am not that familiar with all B&O´s solutions.
From the beginning - it started with that I wanted to have a soundsystem that was really good and could play at a high volume. A real party machine! Airplay, spotify, DLNA could all be integrated. Since I do like B&O, if I have to see the speakers, the choice was easy. Then I wanted to combine the music solution with the TV. Not the best sound in a TV, as you know. And now my wife started to brawl..... :-) 1 remote.
And here I am! :-) Thank you for all good advices and please, enlighten me with all your ideas to make this work!
Tomas
Posts 38
Tomas replied on Thu, Jan 3 2013 8:29 PM
Regarding the volume setting, the best way is to set the BL5 to almost max as a starting volume when turned on, then you control the volume with the onkyo.
bayerische
Ekenäs, Finland
Posts 4,770
Hugolainen:
OK, just put to A to the B with "Hugolainen"...
Try finding 4 used in Finland... Stick out tongue That's why I asked. I bought mine from Denmark.
bayerische
Ekenäs, Finland
Posts 4,770
Tomas:
But...
Also a great way to destroy the speakers by accident...
bayerische
Ekenäs, Finland
Posts 4,770
Hugolainen:
bayerische:
The Beosystem 3 has all those integrated. It's basically all the electronics from the BV7/BV9 without the screen.
Have a look
It's going to be rather expensive, even used. But it will solve all your problems. As you'll get everything connected to it the proper B&O way, and you'll only need one remote control.
Doonesbury
Landisville, PA, USA
Posts 168
Rather than get a "receiver", why not get a preamp/processor?  It looks like all of your speakers are powered so you shouldn't need the amplifiers in the receiver.
David
Hugolainen
Posts 10
Hi All and thanks for your great inputs!
Think I am getting a grip of it now. (Remember I am not a techie) :-) too bad B&O always need special solutions - especially when they are quite pricey towards other brands.
Beosystem 3 might be a good solution. One thing I do not like is that it is not any upscaling to 4K. As mentioned earlieir - I use internet TV so having a few TV:s make it not being able to have HD. That sucks for sure.
And it is only 50Hz where the TV´s scale to 100 -200 and even 600 hz. That will be standard soon.
Any thoughts?
Hugolainen
Posts 10
Will that sort out the issue with volume ? Have thought of that solution and there are other brands that manages that.
Do you have a special brand in mind?
Tomas
Posts 38
Tomas replied on Sat, Jan 5 2013 12:10 PM
bayerische:
Tomas:
But...
In the same way as it's getting run over by a car, if your somewhat cousious it doesn't happen.
Since the BL5's will only be connected to the preamp/amp then the volume setting is done there.
I've been running a setup lite this for about a year now, with no problems.
Doonesbury
Posts 168
That is good to read.  I thought I read of something like this, but I haven't been able to find it (but I'll keep looking).
I brought up this issue on a later post that was prompted by this question.
David
Magnus
Norway
Posts 331
Magnus replied on Sat, Jan 5 2013 7:59 PM
I don't think I would recommend to buy a Beosystem 3 at this time... Just get a cable that feeds the speakers with the pre-out signal from the Onkyo and at the same time take the 12V trigger from the Onkyo (I assume it has triggers?) down to 5V and feeds it to the speakers, and bob's your uncle! The speakers will turn on when the Onkyo turns on, and off when it turns off, and all the sounds-settings will be controlled by the Onkyo.
I don't see why it shouldn't work, and I don't see a reason to use the Beolabs in non-beo mode.
Magnus
Hugolainen
Posts 10
What processor do you use?
Or, what do you recommend to use? :-)
Hugolainen
Posts 10
Magnus, how come your statement about BS3?
And Why not use the BL5 outside a beosetting?
Magnus
Norway
Posts 331
Magnus replied on Sun, Jan 6 2013 12:12 AM
If you're only interested in Beolab 5, and not the other parts of "the B&O experience" (Beolink, Beo4++), I don't think that the Beosystem 3 is the way to go. It's getting old and expensive, and I think a normal receiver will do the job just fine.
About non-beo mode vs. beo-mode:
As far as I understand, if the Beolab 5 is in "non-beo mode" it expects a fixed line in and you will have to regulate the volume and turn them on via the Beo4. Of course, you could set the volume high and then regulate it with the Onkyo, but you will still have to turn them on with Beo4.
But if they are in "beo mode" aka. they think they are connected to a Beosystem, they will behave like a normal Beolab; turn on when they get a trigger signal and no volume control. I think this will be the easiest in your setup, as the Onkyo will control everything.
I'm by no means an expert, but I think this is how they work. I would ask Steve at Sounds Heavenly (ad on the bottom of the page) for help with the cable, he probably knows!
Or maybe a real expert swings by this thread!
Magnus
Edit: If your planning to use a Beolab 7 with non-beo equipment, I'm pretty sure you have to make a special cable anyways, as I don't think Beolab 7 have a line mode! It will be a cable like THIS.
Tomas
Posts 38
Tomas replied on Sun, Jan 6 2013 12:54 AM
Right now an old Thule , works fine for the job.
Im looking into getting a used bv4/bs3, but that combo seems to have to many limitations so im not sure anymore if thats the way to go..
bayerische
Ekenäs, Finland
Posts 4,770
But if they are in B&O mode, I don't think there will be a preset sound level in the speakers themselves, as this is then set by the "Beomaster".
As a side note, I never understood the point of having 4 Beolab5's in a surround setup. The signal being fed to the rears is pretty limited... It looks good, but is there a huge sound benefit?
Cool to have four though...
My system is completely different from yours, but I'm happy with it, and it really is the only possible way for me, to keep the one remote platform, and I enjoy the design of my Beosound 9000 so much, that it's OK to have it just for "control". Yes - thumbs up
Maab
Posts 95
Maab replied on Tue, Jan 8 2013 5:01 AM
It's embarrassing... but I don't see the trigger IN on the bl5. Where is it?
Page 1 of 1 (26 items) | RSS
